It is currently Mon Sep 15, 2025 12:01 am
 Post subject: Cam clamps wood choice
PostPosted: Fri Jan 26, 2024 7:09 pm
I'm going to build some cam clamps and thought oak would make a good choice but the last few times I've worked with oak, I've gotten skin and eye reactions. What's a good alternate to oak? Ash?
Thanks in advance,
PostPosted: Fri Jan 26, 2024 7:25 pm
I think I would go for beech.
These users thanked the author Colin North for the post: Kbore (Sun Jan 28, 2024 12:34 pm)
PostPosted: Fri Jan 26, 2024 7:46 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Mine are made out of maple.
These users thanked the author doncaparker for the post: Kbore (Sun Jan 28, 2024 12:33 pm)
PostPosted: Fri Jan 26, 2024 7:57 pm
The ones I made I used maple too.
These users thanked the author SteveSmith for the post: Kbore (Sun Jan 28, 2024 12:34 pm)
PostPosted: Fri Jan 26, 2024 8:11 pm
First name: Trevor
Last Name: Gore
City: Sydney
The traditional timber to use is Hornbeam. Mine are made from Aus. blackwood (higher density stuff) and work fine with aluminium shanks. I didn't use pins on the sliding part and they still work perfectly some 15 years on.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Kbore (Sun Jan 28, 2024 12:32 pm)
PostPosted: Fri Jan 26, 2024 8:13 pm
City: U.P.
Just a vote for hickory. Made some I like, strength to weight is good.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Kbore (Sun Jan 28, 2024 12:33 pm)
PostPosted: Fri Jan 26, 2024 9:51 pm
I've made quite a few and mostly from maple. I have few long reach ones from my early archtop, parallel brace days that have a 9" reach and are, without running down to measure, 1 1/2" by 1 1/2" wooden bars with 1 1/4" x 1/8" steel flatbar that can put some serious clamping pressure down compared to the average cam clamp.
These users thanked the author Darrel Friesen for the post: Kbore (Sun Jan 28, 2024 12:33 pm)
PostPosted: Tue Jan 30, 2024 12:27 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I used oak (leftover flooring I glued up). Price was right - - - zero. Waste not, want not. And I figured the time spent was worth it, I didn't grudge the time.
Peter Havriluk
PostPosted: Sat Feb 03, 2024 1:42 pm
I've used several woods over the years. I'm not a fan of Ash. The best wood for me has been Birch and Hard Maple. In fact, I have some that I used Hard Maple for the bar instead of metal.
Brent
PostPosted: Sat Feb 03, 2024 1:57 pm
I made mine out of maple, they work great.
PostPosted: Sun Feb 04, 2024 9:00 am
I recently made about 50 clamps to go completely around a guitar body when gluing on the back or top. I went a different direction and made the clamps from 3 layers of 1/4" Baltic birch plywood so I didn’t have to cut mortises. They’re not super strong but are up to job they are intended for.
PostPosted: Sun Feb 04, 2024 10:15 am
Do you prefer cam clamps to a go bar deck Barry?
PostPosted: Mon Feb 05, 2024 9:19 am
Yes I do, for this specific operation. Go bars work great for bracing but did not work that great for me when clamping tops or backs to the rim. I built a body for an old Martin 00-17 that has no body binding and I discovered that I was not getting a completely closed joint line due to the go bars not applying pressure in exactly the right spot along the outside of the joint. Cam clamps do a better job of closing the joint especially if you position them so that the flexible clamp pad can shift and follow the slightly tilted edge of the arched rims.
Users browsing this forum: No registered users and 89 guests
